North East Buses Local Bus Scene Operations, Management & Infrastructure State of North East Transport
  • 2 Vote(s) - 3.5 Average
Pages (2): Previous 1 2
4693
03 Jul 2023, 4:23 pm
#21
(03 Jul 2023, 9:30 am)RMF1254 Fair enough, I am talking about my experience. I use Nexus timetables all the time alongside Bus Times and never seem to have a problem. A couple of examples mentioned, the 57 timetable shows the whole route and the 51 shows the whole timetable including the GNE evening journeys.
That must've changed relatively recently as last time I looked the timetables were all split by operator so stuff like the 29 you'd end up with 3 timetables. Complicated as an understatement.
(03 Jul 2023, 1:45 pm)deanmachine I mean yeah, but it tells you to do some silly things. Like getting a bus 1 stop when it's just easier to walk. You can tell some of the foreign users who aren't familiar much with the area use google maps because you'll see them following it to the letter which isn't always the best way to get somewhere.
Aye hopeless, I've found the same with Traveline aswell which is even worse, the idea of walking 200m is just alien and it comes up with some rather random routes as a result changing in totally inappropriate places.
(03 Jul 2023, 3:04 pm)V514DFT Im concerned about the Metro, theyre getting new metros granted, but even with battery power aswell, i dont see 46 being enough, especially with all the proposed routes/extensions they want to do, they already upped it from 42 to 46, i know the layout is different on the 555's have 5 articulated sections rather than 4 (combined from 2 carriages), as for buses, i said it in another thread, it should always be seen as a "work in progress" rather than "that'll do", then operators moaning that "due to low passenger numbers" yeah, you have low passenger numbers cus you wont adapt properly, and use a model from the 1980's
Tbf it's quite an increase from now they've only got 35 operational units and that's when they're all on the tracks which they're not. Believe the current full daytime units is only 27 units or so, so there's a very lot of slack. If they can't operate that (will go upto 34 or so with the timetable increase) then there's something very wrong.
Mind hopefully the launch goes better than the Class 777's in Liverpool which are the same train thereabouts and having a bad time blighted with problems.
Storx
03 Jul 2023, 4:23 pm #21
2290
03 Jul 2023, 5:10 pm
#22
(03 Jul 2023, 4:23 pm)Storx That must've changed relatively recently as last time I looked the timetables were all split by operator so stuff like the 29 you'd end up with 3 timetables. Complicated as an understatement.
They've already started scrapping the old units, 4055 left last week after being out of action for quite some time, i suspect its been a parts donor, aswell as 4062 which were both residing in the centre in South Shields, so i expect that will go next, and most of us already know about 4022 which was uneconomical to repair after it derailed in the depot in 2017, i just wonder if its a little premature, 555001 and 555002 were sent back, and still havent arrived, so far they only have 555003/4/5 which are only in the testing phase
V514DFT
03 Jul 2023, 5:10 pm #22
03 Jul 2023, 6:00 pm
#23
Apart from the ones that get on your 4 when it clearly says get the 12 (that actually happened the other week).
Another issue with google maps is it doesn't tell you which side to be on - not much of an issue for trains but on certain road, yeah it can cause problems: I once had someone flag down my 18 on Chester Road trying to get to Chester-le-Street!
F114TML
03 Jul 2023, 6:00 pm #23
4693
03 Jul 2023, 6:15 pm
#24
(03 Jul 2023, 5:10 pm)V514DFT They've already started scrapping the old units, 4055 left last week after being out of action for quite some time, i suspect its been a parts donor, aswell as 4062 which were both residing in the centre in South Shields, so i expect that will go next, and most of us already know about 4022 which was uneconomical to repair after it derailed in the depot in 2017, i just wonder if its a little premature, 555001 and 555002 were sent back, and still havent arrived, so far they only have 555003/4/5 which are only in the testing phase
There's loads more off that just those two like. Btw this is the full list of current units and their status, thanks to @DanNCL on RailUK - https://www.railforums.co.uk/threads/met...ro.244590/
Key:
Green - operational
Red - withdrawn
Orange - not operational, may return to service in the future
Blue - Under attention
Purple - non passenger use
Grey - removed from Nexus property but survives
Strikethrough - Scrapped
Units marked with * did not undergo the 2010-2015 Wabtec refurbishment, instead receiving corrosion repairs and RVAR mods at Gosforth between 2018-2020. They are not compatible with the wider fleet in service, however may run together empty.
Units marked with = did not receive the new male auto announcements in 2014-2015 and retain the previous female auto announcements. Announcements are controlled by the leading unit, the announcements installed on the leading unit will play through the full formation.
4001* - stored at Gosforth (avoiding line) pending transfer to the North Tyneside Steam Railway for preservation. Vandalised. Last ran in 2021
4002* - stored at Gosforth (East End), unlikely to return to service. Vandalised and missing pantograph. Last ran in 2022
4003
4004 - stored at Gosforth (main depot)
4005 4006 4007 4008 4009
4010 - stripped for parts, stored at Gosforth (avoiding line). Last ran in 2022
4011 4012
4013 - damaged in level crossing accident at Callerton Parkway 29/06/23
4014 4015 4016 4017 4018 4019
4020 - stored at Gosforth (main depot), believed to be earmarked for preservation at Beamish Museum. Last ran in early 2023.
4021
4022 - Scrapped at Nemesis Rail, Burton-on-Trent, early 2020 - last ran in July 2017. Both cabs have been saved and are at Gosforth depot.
4023
4024
4025 - stored at Gosforth (main depot)
4026 4027 4028 4029 4030 4031 4032 4033
4034 - stored at Gosforth (main depot)
4035 4036 4037 4038
4039 4040*
4041 - training unit at South Shields, unlikely to return to passenger use. Last ran in passenger use in late 2022/early 2023.
4042
4043 4044 4045
4046 - stored at Gosforth (main depot). Vandalised
4047 - training unit at South Shields, unlikely to return to passenger use. Last ran in passenger use in late 2022/early 2023.
4048 4049 4050 4051
4052
4053
4054
4055 - Left by road for scrap at EMR Tyne Dock on 28/06/2023. Last ran in passenger use in 2021, was in training use until early 2023.
4056
4057
4058
4059
4060 - stored at Gosforth (avoiding line), presumed withdrawn. Last ran in 2022. Vandalised
4061 - stored at Gosforth (main depot). Last ran in March 2023
4062 - Left by road for scrap at EMR Tyne Dock on 29/06/2023. Last ran in passenger use in 2021, was in training use until early 2023
4063
4064 - stored at Gosforth (main depot)
4065 4066 4067 4068 4069
4070 - stored at Gosforth (main depot). Missing components
4071 4072 4073= 4074
4075
4076 - stripped for parts, stored at Gosforth (avoiding line). Last ran in 2022. Vandalised
4077 - stored at Gosforth (main depot). Missing components
4078 4079 4080 4081=
4082 4083* 4084
4085 4086 4087 4088 4089
4090
Storx
03 Jul 2023, 6:15 pm #24
Key:
Green - operational
Red - withdrawn
4003
4011 4012
4021
4023
4024
4035 4036 4037 4038
4039 4040*
4042
4043 4044 4045
4048 4049 4050 4051
4052
4053
4054
4056
4057
4058
4059
4063
4075
4082 4083* 4084
4090
1124
03 Jul 2023, 9:54 pm
#25
That's a lot of vandalised units.
idiot
03 Jul 2023, 9:54 pm #25
4693
03 Jul 2023, 10:19 pm
#26
(03 Jul 2023, 9:54 pm)idiot That's a lot of vandalised units.
Aye they all got tagged on the Gosforth depot avoiding line, there's pictures here - https://www.railforums.co.uk/threads/met...st-6184143
Storx
03 Jul 2023, 10:19 pm #26
14275
07 Jul 2023, 10:35 am
#27
It's knackered.
Well and truly knackered.
The infighting, the bickering, the politics, the self-preservation, the snideyness, the general incompetence, the lack of commercial awareness, the pigheadedness and the total failure to adapt (and there's probably a whole load of other terms that could be used) has all resulted in what we see now.
We've only got to say thank you to Covid, for speeding up the inevitable demise of public transport as we know it here in the North East.
I'd have been sacked if I was as bad in my job as some people involved in public transport are/have been in theirs.
I'd also be ashamed to have presided over or been involved in the mess.
More or less everything the 'naysayers' and 'bashers' on this forum have been bleating on about has proven true.
We've even seen fanatics and adorers comments change over the years.
The Gravy Train Express is slowly rolling in to Inevitable Demise Central, previously calling at Begging Bowl Town, Shareholder Parkway and Handout Junction. Having missed out Passenger Interest Interchange on the way.
Andreos1
07 Jul 2023, 10:35 am #27
It's knackered.
Possibly Related Threads…
Replies 2
Views 1557
19 Aug 2021, 9:27 pm
Last Post by BusLoverMum
Replies 16
Views 7833
27 Jul 2021, 12:19 pm
Last Post by Andreos1
