RE: BSIP Improvement Suggestions
(11 Jan 2026, 5:28 pm)Storx wrote Talking about Heworth, there badly needs to be some serious discussion about how to serve Central Station coming from the South.
Since the Northumberland Line has opened, it hasn't half opened up my eyes how diabolical the links are to pretty much everywhere which isn't the Metrocentre.
Changing at Gateshead for one stop, isn't the answer either as it's a huge inconvience and nor is walking 15 minutes from John Dobson Street inbound either. It's very different
The ironic thing is already do a loop which has a bus stop nearby at the High Level Bridge but we've got an obsession of terminating everything at a bus station or the middle of nowhere which imo isn't needed for turn up and go services like the 21, 56, 58, X1 etc.
They could easily do something like:
Which would give links to every part of Newcastle ie. someone who works at the new HMRC, can get on the bus outside for Low Fell rather than having to trail across half of Newcastle, similar for Central the opposite way.
Not against the idea. But the on-street infrastructure, bus stop placements and general information provision within the city would need to be drastically improved.
(12 Jan 2026, 12:21 pm)Storx wrote Aye agreed, it's just a mess now but do agree I'm not sure two way on the High Level Bridge..
Btw I do think BSIP should be used though, but not towards the operators but more about making road improvements to make it work, stuff like potentially making Collingwood Street two way like you mentioned above.
Truthfully Newcastle, needs to decide what it's long term bus plan is which includes closing Blackett Street, for once and all, and come up with something sensible
Like away from the loop (you could still do it) imo the network should be something like:
Which breaks up the Stagecoach services so it's not all slammed down Market Street, with the bottom end of Grainger Street going one way with the orange bits going pedestrianised because they should be imo. Would fix most issues really.
There's absolutely no guarantees operators would use it though.
All that tax payers money used and on a whim, operators decide not to use it.
It's happened many times before and I can't see it changing any time soon.
Just going back to your map, there was a period after Worswick Street closed, when a big chunk of the local cross-Tyne services operated an in/out type route, like the 27 takes now.
There were slight variants, such as some turning left down the Bigg Market off Grainger Street and others continuing down towards Central Station, back along Collingwood Street and then right on to the High Level Bridge.
Obviously it was two-way at the time, but the Durham and Washington services would come in off the High Level Bridge, turn left on to Neville Street and work their way up to Newgate Street.
So many options, which allowed people to get a bus which took them to their preferred part of the town.
On a personal note, I'm meeting some mates in the town towards the end of the month.
Some are bus-ing it, some coming on the Metro and others via train (but could bus there if push came to shove. Couldn't get back on the bus due to the ridiculously early finish times).
The only convenient meeting/drinking point (without a hike) is in the area around Central Station.
For a city like Newcastle, that shouldn't be the case.
(12 Jan 2026, 1:53 pm)cr51xln wrote Perhaps sending the diverted buses from Blackett Street onto new stops at Percy Street, so Grainger Street and Newgate Street aren't getting hundreds more buses per hour?
Aye could do, loads of options really like.
(12 Jan 2026, 4:30 pm)Kimlfixit wrote Not against the idea. But the on-street infrastructure, bus stop placements  and general information provision within the city would need to be drastically improved.
Yeah definitely, it's where the BSIP would come in and it would be worthwhile imo.
(12 Jan 2026, 4:33 pm)Andreos1 wrote There's absolutely no guarantees operators would use it though.
Some are bus-ing it, some coming on the Metro and others via train (but could bus if push came to shove).
Yeah agreed to be honest; mind the time Newcastle takes to do work, Northumberland Street has took the best part of 2 year, the things will be franchised by then.
It's a nightmare, kind of only realised with the Northumberland Line how bad it is really is. The more illogical stuff is stuff like the 21 serves the new HMRC on the way in but if you want to return you have to trek half way across town. It's a bit illogical really.
It's not helped that the bus station from the South is at the North side of city either mind; like it wouldn't be too bad if you had to walk in the right direction to catch your bus, but Eldon Square is the complete wrong direction. If only there was a bus station near the new HMRC site, oh wait...
(12 Jan 2026, 4:40 pm)Storx wrote Aye could do, loads of options really like.
To be fair I had been thinking about this when it was being built, doesn't have to be a massive interchange but small one with 5-6 stands could've fitted in on Pilgrim Street.
Other than Five Guys and Nationwide is anything else in The Pearl Complex as that brutalist eye sore could be knocked down to make space.
(12 Jan 2026, 5:37 pm)Malarkey wrote To be fair I had been thinking about this when it was being built, doesn't have to be a massive interchange but small one with 5-6 stands could've fitted in on Pilgrim Street.
Aye, to be honest I'd be tempted to look at the other side of the road; over by the Art Gallery. Still quite a few places you could build one and could be the catalyst which regenerates that part of town including the 'closed' hotel.
It's no further than Haymarket is from the core and could mean that New Bridge Street etc could be pedestrianised aswell. Even better if you could connect it to Manors Metro and Rail station as a hub with a short walk.
It's so much nicer around there with the original renders without the traffic:
[Image: _125665209_mediaitem125665208.jpg.webp]
(12 Jan 2026, 7:11 pm)Storx wrote Aye, to be honest I'd be tempted to look at the other side of the road; over by the Art Gallery. Still quite a few places you could build one and could be the catalyst which regenerates that part of town including the 'closed' hotel.
If we're looking at the other side by the Art Gallery I would look at removing the cycle lanes on John Dobson Street/Saville Place and reconfigure the bit aligned with North Street highlighted in orange as Option 1 or remove Saville Place Car Park as Option 2 in green.
(12 Jan 2026, 7:31 pm)Malarkey wrote If we're looking at the other side by the Art Gallery I would look at removing the cycle lanes on John Dobson Street/Saville Place and reconfigure the bit aligned with North Street highlighted in orange as Option 1 or remove Saville Place Car Park as Option 2 in green.
Aye, I was thinking there tbh. Portland House was the other one I was thinking as it's a hideous building and belongs in a business park from the 90's. Could turn the old building into a little coffee shop / waiting room (forgot it's name) and build it around it.
Unsure who's in there these days since Newcastle Building Society left for Cobalt and don't think anyone will miss the 'blue' carpet.
(12 Jan 2026, 7:37 pm)Storx wrote Aye, I was thinking there tbh. Portland House was the other one I was thinking as it's a hideous building and belongs in a business park from the 90's. Could turn the old building into a little coffee shop / waiting room (forgot it's name) and build it around it.
Portland House is now owed by a Company called Wizu who have refurbished the office space completely and have a few different tenants including ICPlanning, ECO4HOMESUK and Omnicom Media Group. https://wizuworkspace.com/location/portland-house/
(12 Jan 2026, 9:35 pm)Malarkey wrote Portland House is now owed by a Company called Wizu who have refurbished the office space completely and have a few different tenants including ICPlanning, ECO4HOMESUK and Omnicom Media Group. https://wizuworkspace.com/location/portland-house/
Aye that's fair wasn't sure if there's actually anything in there or if it was like half the ones with Cobalt which are completely empty and have been since they were built aswell.
With funding being agreed "subject to value for money" for the re-opening of the Leamside Line in coming the years I had wondered if in the interim a Bus Service of some form would potentially work, I had a look through the Bygone Era/Old Timeables and had seen in the 80's/90's Northern operated Expresslink through to Broomside from Newcastle so I used this as basis of creating a service in which I have came up with these below.
X23/X24 - Newcastle - Gateshead - Low Fell - Chester-Le-Street - Durham - Gilesgate - Belmont - A690 - Leamside - Woodstone Village - Low Pittington - High Pittington - Broomside - Sherburn Village - Shincliffe - New Elvet - Durham - Chester-Le-Street - Low Fell - Gateshead - Newcastle
X25 - Durham - Gilesgate - Sherburn Village - Broomside - High Pittington - Low Pittington - Leamside - Woodstone Village - Bournmoor - Shiney Row - Washington Galleries - A1 - Angel Of The North - Low Fell - Gateshead - Newcastle
X26 - Durham - Gilesgate - Sherburn Village - Broomside - High Pittington - Low Pittington - Leamside - Woodstone Village - Bournmoor - Shiney Row - Penshaw - Pennywell - Chester Road - Royal Hospital - University - Sunderland
(24 Jan 2026, 9:30 pm)Malarkey wrote With funding being agreed "subject to value for money" for the re-opening of the Leamside Line in coming the years I had wondered if in the interim a Bus Service of some form would potentially work, I had a look through the Bygone Era/Old Timeables and had seen in the 80's/90's Northern operated Expresslink through to Broomside from Newcastle so I used this as basis of creating a service in which I have came up with these below.
Surely any Leamside service would have to run something like:
https://www.google.com/maps/dir/54.96994...?entry=ttu&g_ep=EgoyMDI2MDEyMS4wIKXMDSoKLDEwMDc5MjA2OUgBUAM%3D
It's basically what it does, but it's a bit of a duplicate of the 4 really.
Personally I think you'd better doing a new Washington Express service running every 30 minutes, 15 minutes combined giving the vast majority of Washington a direct bus service to Newcastle and integrating the 82 into it like this:
I think it's crazy you can't get a direct bus to Newcastle from pretty much all of Washington and I can't see at all how there's no demand for it. The bonus of that route is you get Concord, Birtley and Washington Galleries links added as a bonus and give a better service to not Durham Road in Birtley which equally an absolutely appalling service.
Talking about improvements the current Go NorthEast 61 service is just a mess and I can’t believe how farcical this route is.
A family member, auntie, used it from South Hetton to Sunderland and the quote from her was ‘never again’. It took 1hour 20 minutes, majority of which seemed to be spent looping Murton. Checking over the timetable, it seems it takes 25 minutes get to Dalton Park from the top of Murton, a journey which would take a car 4-5 minutes maximum and even the 65 manages in 12 minutes. Who is this service for?
Having used traveline, it seems had my Auntie gone out for a bus 5 minutes earlier, she could have used the X1 from South Hetton to Houghton then caught the X20 into Sunderland - this would have got her into Sunderland 16 minutes earlier than the ‘direct’ 61… surely this Peterlee extension is actually serving no purpose, anyone using it must perhaps not know the alternatives available, or are just using the direct service to save changing buses… but this doesn’t mean a good service is being provided for passengers.
I had seen in this thread the mention of the old 202/62 route being reinstated and I have to agree that council subsidy is supporting this marathon 61 route, but this where the system is broken. Because financially supporting a whole new route by bringing back the 62/202 may cost more, but would an overall better service be provided? Because at the minute I fail to see why Durham County council are supporting this route at all…
(25 Jan 2026, 2:24 am)Drifter60 wrote Talking about improvements the current Go NorthEast 61 service is just a mess and I can’t believe how farcical this route is.
I don't know what the demand is like from Murton to Peterlee but I'd say bring back the 55 instead personally.
The 35 route to Sunderland is stupidly long aswell going on a mystery tour around Houghton Le Spring for people from the likes of Hetton etc.
Just number it the X19 or something and interwork it with the X20 so it's a 15 minutes express between Sunderland and Houghton.
(25 Jan 2026, 8:17 am)Storx wrote I don't know what the demand is like from Murton to Peterlee but I'd say bring back the 55 instead personally.
The 35 doesn't go to Houghton Le Spring etc.
(25 Jan 2026, 10:18 am)Michael wrote The 35 doesn't go to Houghton Le Spring etc.
32 sorry. Forgot they split it in half, quite recently. Was the 35 for years.
The big three comes with pros and cons, but with the mayor keep mentioning taking buses back under public control, if this is to be a success things like the 61 route need to be looked at, someone in South Hetton should have a bus to Dalton Park that doesn’t take 30-35 minutes when it’s a car journey of 10 minutes or a route to Sunderland that isn’t 70-80 minutes long.
The 61 is a classic case of being the bus world of a ‘jack of all trades, master of none’, there’s probably many across the bus network like it where existing services have been diverted to cover gaps in the network but the end result is routes that no longer good to either set of passengers.
(25 Jan 2026, 7:47 pm)Drifter60 wrote The big three comes with pros and cons, but with the mayor keep mentioning taking buses back under public control, if this is to be a success things like the 61 route need to be looked at, someone in South Hetton should have a bus to Dalton Park that doesn’t take 30-35 minutes when it’s a car journey of 10 minutes or a route to Sunderland that isn’t 70-80 minutes long.
I don't get why it's still like that, in reality it should be a separate route than the regular 61, just take the 65 route through Murton, that would knock 20 minutes off straight away.
(25 Jan 2026, 9:12 pm)deanmachine wrote I don't get why it's still like that, in reality it should be a separate route than the regular 61, just take the 65 route through Murton, that would knock 20 minutes off straight away.
The 65 already goes through Murton and it gets absolutely jam packed full of people on a single decker.
(26 Jan 2026, 7:28 am)TheClumsyPineapple wrote The 65 already goes through Murton and it gets absolutely jam packed full of people on a single decker.
The poster knows that. The point being made is if the 61 Peterlee trips followed the 65 route in Murton, it would be a much quicker service.
(26 Jan 2026, 4:40 pm)Drifter60 wrote The poster knows that. The point being made is if the 61 Peterlee trips followed the 65 route in Murton, it would be a much quicker service.
Just double checking!
(25 Jan 2026, 12:09 pm)ASX_Terranova wrote Heres a suggestion, a pot of funding for anyone but the big three. See if anyone with a fresh pair of eyes can do something good.
I suppose the issue is...what happens when the funding stops (to be fair that is an issue anyway). Do the councils need to find extra money above their normal budgets or do they think about new links which which won't need public support when the money dries up.
Unless there is a backstop, I can see a lot of BSIP funded services going by the wayside, even if they have proven some value.
I was thinking about how this money could've and should've been used, rather than reintroducing pre-COVID frequencies on routes that could've managed without them.
Firstly, introduce ticketing such as the PoP card, but used as the Oyster Card down in London. Same pricing, tap on/off caps on the day ticket. This technology is not hard and just takes some willpower to implement. Heck and standardise the ticket machines used by the operators, so this could have been done even quicker. I'm sure the big 3 (plus more) would not complain about free or heavily reduced brand-new ticket machines. So standardised tickets mean Qualifying Agreements are made redundant because this would be the norm.
This would've been a good suggestion to use BSIP money to improve lots of local connections... And focus on Corridor Qualifying agreements such as Newcastle (Coast Rd, West Rd, Great North Rd), Sunderland (Chester Rd, North Hylton Rd, Durham Rd) & Durham.
Secondly, streamline operational areas and try to create new links either by merging current routes or creating new ones. For example, East Durham  (a random area chosen) changes could be...
X1 - Peterlee terminating services extended to Hartlepool (timed with the 61 instead of the 23/24 x15 mins freq)
X6/X7 - X6/X22 merged to make hourly connections from Sunderland to Darlington(old X21)/Middlesborough
60 - merged with 24 to create links South Shields - Parkside
61 - 22/23 merged so that it would be Sunderland to Hartlepool (vital links currently only unavailable by bus)
62 - 61/9 merged Jarrow to Murton
63 - 22/49 merged Langley Park - Peterlee
64 - 64/24 merged Arnsion Centre - Peterlee
65 - 64/65 merged Arninson Centre - Seaham
201/202/206/208/209/210 Peterlee locals work off the 63/64 as the X6 no longer terminates at Peterlee
Simple changes to numbering/routing make everything easier to understand and create new/more links...
Thirdly, invest properly in safety features at stops/stations/interchanges and reduce evening fares (which were extremely popular during GNEs useage of these).
Such as £1.50 single for local journeys and £2 for longer distances (a rough example)
(05 Mar 2026, 1:45 am)logidoodah wrote I was thinking about how this money could've and should've been used, rather than reintroducing pre-COVID frequencies on routes that could've managed without them.
The ticket machines, WiFi and contactless payments were all funded (partially or fully) by the taxpayer.
Shared the documents previously on here.
In it, you can see how much and when each operator recieved, so they could implement the schemes.
They all applied independently. All got their pots and each bought different machines.
And at the same time, Nexus were sorting out their Pop card launch.
This would have been *around* 2015 and launched a year or two later.
(05 Mar 2026, 12:54 pm)Andreos1 wrote The ticket machines, WiFi and contactless payments were all funded (partially or fully) by the taxpayer.
The problem here is clearly Nexus. Private operators will take money, no matter how strict or not the terms.
Why did Nexus persue a archaic Smart card solution, when other PTE areas are app or payment card based?
The West Yorkshire Metro Mcard app is a game changer which can be used on bus and heavy rail....and we are stuck with paper tickets and Metro barriers which can't accept a card payment or scan an m-ticket barcode. It's Beamish ticketing in 2026 and Nexus are mostly to blame
(05 Mar 2026, 4:55 pm)Kimlfixit wrote The problem here is clearly Nexus. Private operators will take money, no matter how strict or not the terms.
How many operators had fully functioning card payments or apps back in 2015?
They were using the same tech. Countrywide.
https://www.gov.uk/government/news/roll-...r-millions
(05 Mar 2026, 6:47 pm)Andreos1 wrote How many operators had fully functioning card payments or apps back in 2015?
To be fair, it's a Nexus issue here mind.
They all used ITSO (https://www.itso.org.uk/) and still do, including the mobile stuff (https://www.yotra.co.uk/)
It's not the operators fault for lack of any tickets, they have the equipment. It's Nexus for not doing any tickets; Swift in the West Midlands is using the same system, the difference is there's actually works and the one up here is an embarrassment, and that's being complimentary.
Its the same tech, but Nexus have went down the completely wrong avenue. It's Nexus that had the ability to define the specification for the Pop card app and Metro barriers. A clearer specification for both could have enabled better ticketing integration aligned with the tax payer funded equipment currently in use by bus operators today!
Because of decisions made years ago, I can download an app in West Yorkshire, use any bus and train by simply scanning a bar code at barriers and on bus and away I go, but in the north east I have to wait for a metro bod to look at my ticket on a phone before letting me through. It scans on the buses though! That 100% on Nexus
Why can't I buy a network one ticket on the pop app? it's absolutely insane
