(27 Feb 2026, 8:10 pm)Storx wrote Aye that's fair, I know you'll get some people who will go on it's shocking not letting people have a say and what not, but let's be honest there's nothing worse than fake consultations and it's blatantly obvious when they do it aswell.
Btw speaking of consultations, I'm assuming the X22 changes aren't going ahead with it staying towards Stockton? It's just gone very quiet as if the consultation never existed.
The outcome I believe was to just keep the current X22 route to Stockton.
IJimmi
The consultation didn’t happen in the end. Was taken down rather quickly when local councillors (the same ones that complained about not having a link to Darlington) kicked off massively that people would have to change buses at Sedgefield to reach Stockton and North Tees Hospital. At risk of causing more chaos. An easy fix would be to have the 59 run Hartlepool-Darlington instead of Hartlepool-Durham. Trimdon would loose a direct service to Durham but would gain direct buses back to Aycliffe and Darlington
(01 Mar 2026, 12:01 am)220631612 wrote IJimmi
Issue with that is Durham CC (/NECA) pay for the 59, and I can’t imagine they’d want to fund a bus to Darlington (TVCA)
(01 Mar 2026, 12:08 am)tyresmoke wrote Issue with that is Durham CC (/NECA) pay for the 59, and I can’t imagine they’d want to fund a bus to Darlington (TVCA)
But they already do fund the same bus into Tees Valley when it enters Hartlepool? TVCA don't pay anything towards it.
This is the underlying problem with the wider "bring busses back into public control" argument. Politicians have their imaginary lines that the regular bus passengers couldn't care less about. It could make things worse if they are not careful.
Over the years Durham have funded quite a few odd journeys into and out of Darlington. You’ve got to consider Darlington is the major town for most of South Durham.
Surely the point being made there was the 59 in current form is a County Durham route that pops over the boundary into Hartlepool for a short section, but by sending it to Darlington instead it'd become a route largely beneficial to Tees Valley rather than County Durham, starting and finishing in Tees Valley at both ends and only serving a small section of County Durham where other transport links are largely already available, albeit not directly. It reduces the social necessity value of the route for Durham County Council.
(28 Feb 2026, 11:44 pm)Jimmi wrote The outcome I believe was to just keep the current X22 route to Stockton.
Aye that's fair, guessed it was.
Not sure cutting the 59 in half would be a good idea mind, it's just robbing Paul to pay Peter that.
(01 Mar 2026, 10:55 am)Storx wrote Aye that's fair, guessed it was.
A better solution, would be to transfer Hartlepool back into political County Durham. Obviously more complex and not a bus issue.
(01 Mar 2026, 12:00 pm)Economic505 wrote A better solution, would be to transfer Hartlepool back into political County Durham. Obviously more complex and not a bus issue.
imo the better thing would be to merge Tees Valley and NECA as one big area. Both areas are so connected in many ways, it just doesn't make sense being split imo. It's very different to Yorkshire and the North East where there's a very clear split or the North East and Cumbria.
Then stuff like this doesn't become an issue.
Ideally the network needs to run like this:
which connects all the main towns and villages to the key places with the 8/8A/22/X22/23/24/56/58/59/113/X6 being the routes which form the network as imo it's a bit of a mess with too many duplicates, especially 6 BPH from Durham to Hartlepool and 8 BPH from Sunderland to Durham (including the 20/20A). Get them split off going to other big towns imo. The 6/7/X10/X12 staying as they are as they're fine.
(01 Mar 2026, 12:32 pm)Storx wrote imo the better thing would be to merge Tees Valley and NECA as one big area. Both areas are so connected in many ways, it just doesn't make sense being split imo. It's very different to Yorkshire and the North East where there's a very clear split or the North East and Cumbria.
Where do you draw the line?
There will be people in the south of TVCA who cross in to North Yorkshire on a regular basis.
Do they lose out? Or do you merge NY with TVCA and NECA?
You've then got the issue where NY crosses in to WY and so on.
(01 Mar 2026, 6:23 pm)Andreos1 wrote Where do you draw the line?
Nah I get that with NY, and it's always going to be an issue somewhere but it's not as connected imo.
Newton Aycliffe and Darlington need to be together imo as they're economically one place and it's leading to issues like this X21.
Hartlepool and East Durham being the same. Yet they're all dumped with Newcastle which truthfully is probably irrelevant to most people living there.
County Durham all needs to be back together imo and when your at Stockton you might aswell chuck the rest of Teesside in.
(01 Mar 2026, 6:44 pm)Storx wrote Nah I get that with NY, and it's always going to be an issue somewhere but it's not as connected imo.
Whether it's as connected or not, it still needs to be taken in to account.
Theres the X26/27.
The X4 and X93/94.
They're all carrying healthy loads between NY and TVCA and are offering a pretty frequent combined frequency on each.
Then you've got the likes of the 72 between Darlo and Northallerton.
Or the 89 between Boro and Northallerton.
You can't just say 'ah it doesn't matter, because it's not as connected'.
Of course it matters.
How easy it is to fix, is one thing.
But lumping one area in with another, isn't the fix.
For years, people would get on/off the X5 at Snippersgate garage to save the fare difference between Easington Lane and South Hetton.
It was the same at Barley Mow in Birtley and I imagine other places too.
Thankfully, a lot of those fare issues/barriers to travelling are in the past.
They don't need to come back.
(01 Mar 2026, 10:51 am)cainebj wrote Surely the point being made there was the 59 in current form is a County Durham route that pops over the boundary into Hartlepool for a short section, but by sending it to Darlington instead it'd become a route largely beneficial to Tees Valley rather than County Durham, starting and finishing in Tees Valley at both ends and only serving a small section of County Durham where other transport links are largely already available, albeit not directly. It reduces the social necessity value of the route for Durham County Council.
If anything, I think extending the 59 to Darlington would be more beneficial from the Durham end of the route, rather than Hartlepool (Durham - Coxhoe - Trimdon - Aycliffe - Darlington) and instead restore the previous 33 service pre autumn 2012, (Ferryhill - Sedgefield - Trimdon - Hartlepool), the Ferryhill to Sedgefield stretch being the current 113.
Durham was the most requested link for those in the Trimdon Village area in a survey done by the previous MP.
It's also worth noting there's plans to introduce a regular rail service between Darlington and Hartlepool (currently only a handful of journeys on Sunday).
(01 Mar 2026, 7:14 pm)Andreos1 wrote Whether it's as connected or not, it still needs to be taken in to account.
Theres the X26/27.
The X4 and X93/94.
Aye no arguments on transport, I was talking more economic more than just transport though.
Arguably Hartlepool is the county town for some of East Durham and Darlington is the county town for some of South West Durham but there's absolutely no control over either from a region point of view because we've split it in half.
Obviously there's going to be some issues with transport wherever but these exist already anyway.
What we don't have right now is a depot in Darlington with routes being franchised in another county. God knows what the plan is for these as you can't have the whole SW Durham / East Durham network running from Belmont. There's literally currently not another depot for any reasonable size of work. No doubt it's something they haven't thought about it either and will scramble for a solution last minute.
Just had a think about the Coast Road situation. Now, there is scope for 'one' of the service groups (either 306/308 or 307/309) to run a 7-8 minute service, and preferably at least a 20 minute Monday to Saturday evening service on the core sections.
It might be a bit much for Arriva given they have nothing at the Newcastle end of the route. But based on a PVR of 17, would it not be beneficial for Arriva (if legally allowed - similar to the original NMS/Coastline joint 308) to explore joint operation with Stagecoach for a re-increase, who could perhaps run 5 boards out of Walkergate - leaving Arriva with 12 boards out of Blyth?
If they nailed the ticketing arrangements, would be perfect as Stagecoach could easily pick up the early run-on's / late run offs that occur in North Tyneside & Newcastle. And Stagecoach also have experience dealing with plenty of core high frequency urban routes.
Also - could be scope for some 'basic' mutual engineering support for things like breakdowns etc, especially if both were to use E400MMCs.
Not sure where your getting 6 BPH between Durham and Hartlepool from when they is only 3 services between the two.  The 24 every 30 minutes and the 58 and 59 both hourly is only 4BPH between the two.  On Sundays it’s only 1BPH during the daytime.
People keep asking me what's happening with the 81 and new services on Teesside.Rumours are spreading like wildfire and not many of them are good! I'm doing my best to quell the flames but don't have the resources. Not many are on these pages or have the Arriva app and asking the drivers don't appear to know, or have the time to chat.
Roure learning will, no doubt. have being taking place but then wasn't this - according to one driver - been done on a Sunday and kinda 'forced' on them!
I remember some years ago when I used to travel regularly on the then, I feel it was a Tees and District, operated X10 the driver came to his bus, boarded his passengers, set away around the bus station ramp, got to the roundabout and shouted, "right anyone know the way, I've not done this duty before' He was serious and doesn't build confidence given this is now Arriva we are talking about..
Be interesting to hear what people have to say.
With regard to my last? Yes there is news of the service changes on the Arriva app. There are maps - I'll use that word loosely - with the map but two points? One. Not everyone has or wants the app. Plenty people still aren't up to speed with technology and two? Just who complied the maps. If you could ser them it would be a start, understand them? No chance?
(11 Mar 2026, 6:11 am)robisdave4554 wrote With regard to my last? Yes there is news of the service changes on the Arriva app. There are maps - I'll use that word loosely - with the map but two points? One. Not everyone has or wants the app. Plenty people still aren't up to speed with technology and two? Just who complied the maps. If you could ser them it would be a start, understand them? No chance?
It’s also been on the Arriva website for weeks and I would hope there is notices going up on the vehicles as we get closer to the start dates. The maps look fairly simple to me!?
Don’t know why there needs to be rumours when it’s definite what’s happening.
I've seen some of the new Teesside timetables are now on the arriva website (no sign of the new 65 yet though).
The new 28 shows it ONLY as a 2 hourly affair throughout with only FOUR journeys per day beyond Redcar to/from Marske.
Sent from my SM-S928B using Tapatalk
(11 Mar 2026, 8:49 pm)Mark P wrote I've seen some of the new Teesside timetables are now on the arriva website (no sign of the new 65 yet though).
28 is definitely hourly, for whatever reason there's journeys missing on the useless auto generated PDF timetable.
All the upcoming changes/routes do appear if you go to the plan a journey section and change it to a date after the changes commence, although the 81 still showed up when I searched Guisborough to Redcar.
The gaps you see are likely where the Redcar operated journeys need to slot in.
