Service changes suggestions
Service changes 47 , 643 and 91A
643:
To make a direct way , the 643 will follow Sunniside Road out of Sunniside onto Whaggs Lane before coming back onto Whickham Front Street VIA Rectory Lane , instead a replacement 643A will run the already existing route of the 643.
47:
The 47 will use Medomsley Road out of Consett Bus Station which will VIA Pont Road North , Medomsley Manor Road , Hamsterley Mill Lintzford Road , join back on to the already existing route at into Burnopfield New Road , and lead back into Newcastle using A692 , for alternatives on already existing route , use X71 and others including X72 etc.
91A:
91A will run throughoout the day instead of 07:49 and 08:49 and will run until 19:49
Yours Sincerely , EastGatesheadRider X58
EDITED PART
2nd July 2026
This forum is no longer in use
RE: Service changes suggestions
(Yesterday, 4:43 pm)EastGatesheadRider wrote Service changes 47 , 643 and 91A
643:
47:
91A:
That 47 change would never happen. With No X46, the 47 has to fill in for different places such as Shotley Bridge, Bridgehill and Chopwell. What you're suggesting is that all those places lose out their local town connection to have their bus be half duplicated route to the X71 and for the Medomsley route suggestion, They already have 2 Bus services that are every 30 minutes. So if your going to have the 47 go down that way you would have to get rid of the X71.
Next point to put on the 47 is that that would make Consett only have 1 Metrocentre Bus. We had 4 at one point, now at 2. People would hate it alot if it was down to 1.
I'm looking at where your suggesting to run the 47 and I'm confused. You've duplicated the V5 Pont Road to Medomsley corridor and most of the X71 from Pont to Newcastle.
I know its a suggestion but that 47 change would be the worst thing to ever happen
You do know theres already a service suggestion thread for GNE, every service you mentioned there is or has been ran by GNE
